TwinTurbo.NET: Nissan 300ZX forum - How many miles? Low Compression? Boost Leak? (n/m)
RonZ300
on October 17, 2010 at 7:59 PM
Dyno results...
posted by SimaYi
on October 17, 2010 at 07:21 PM
Dyno results...
SimaYi
19:21:29 10/17/10
How many miles? Low Compression? Boost Leak? (n/m) -
RonZ300
19:59:10 10/17/10
Less than 10k miles...
SimaYi
23:07:57 10/17/10
What are compression readings with that head gasket? (n/m)
ZXoltan
20:13:20 10/17/10
yes..you should expect more....
zdoc
20:46:52 10/17/10
I would expect more.
CoHPhasor
21:05:55 10/17/10
CXRacing smics were direct fit...
SimaYi
23:09:07 10/17/10
Direct fit, even stock airguides?
CoHPhasor
00:02:47 10/18/10
Yep, stock vents, they do advertise so.
SimaYi
00:14:52 10/18/10
I'm using CXRacing intercoolers, but they were not good
not4resaleZ
16:49:51 10/18/10
Re: Dyno results...
ztunerz
21:09:04 10/17/10
Re: Re: Dyno results...
SimaYi
23:11:40 10/17/10
Here's my graph
s3trios
22:08:24 10/17/10
I suspect you have a few bottlenecks.
MixManMash
22:21:04 10/17/10
*one intake. (n/m)
MixManMash
22:22:38 10/17/10
Sorry, forgot to update my profile...
SimaYi
23:06:32 10/17/10
perhaps you should find a more experienced tuner
aliaZ
23:06:54 10/17/10
It was tuned by Glenn (txq45).
SimaYi
23:09:53 10/17/10
Re: perhaps you should find a more experienced tuner
txq45
07:44:55 10/18/10
Re: Re: perhaps you should find a more experienced tuner
SimaYi
09:04:57 10/18/10
Graph, but without AFR.
SimaYi
23:43:34 10/17/10
so wait...
aliaZ
23:57:27 10/17/10
at a minimum he should have given you a screenshot
aliaZ
02:29:24 10/18/10
how hot was it outside? what elevation was the dyno at? --->
RonZ300
23:48:32 10/17/10
Re: how hot was it outside? what elevation was the dyno at? --->
SimaYi
23:57:21 10/17/10
Well his HP was significantly higher each run
CoHPhasor
00:09:11 10/18/10
